Hi All,
I hope that some one can help me out with this one:
I have 4 boxes that I've purchased at different times.
Box 1 - Prior purchase:
Avov_tl4k (Build 1.0.7) = Works perfectly and extremely happy with it.
New 3 Boxes - Just purchased:
Avov_tl4k_k (Build 1.0.10) = IPTV does not work. It doesn't connect to the server.
1. Have tried it wired and wireless (browser works, Kodi works as well so we know that network is working)
2. Have done a Factory reset many times
3. Have done a Factory reset and deleted all user data
4. Tried inputting server credentials manually
5. Verified MAC address at the server end and account reseted many times
6. Installer software does updates properly after every reset
The only difference between these boxes is the firmware and I was wondering if there is a newer firmware that I can install on the new boxes or a way to go back to 1.0.7 from 1.0.10)?
Thank you in advance for your time in this matter!
acma2
