Thanks folder2,
my issue is, if tvonline+ works fine on WiFi, than tvonline4 should work as well, i should not have to buy any other hardware.
Thanks folder2,
Maybe avov plus just normally works better with wifi than 4k box does............they may not even have the same Nik hardware for wifi.......two different boxes
online -online + online 4 all wifi work fine ,the 4 is farthest away from router ,no issue,except like i mentioned about shutting down with rear switch other wise freezing always.
see if not freezing on Ethernet that should tell you something
I second what 4wheelin said. I am also experiencing freezing on my avov tvonline 4 if I don't eventually use the rear shut off button.
