Hi I just got home to turn on my Avov TV online + but it does not power on any help please.
you might need to email them at [email protected]
Thank you for your reply.
I don't see a back switch.
your right just went into my son room try a different plug check to see if your getting power
I think it's get power because when I plug it in for a minute I can feel heat but it does not light up or show on TV screen.
Try a different power adapter.........output--5v and no less then 2 amp...can be higher amp but must be 5v
Will do but have to go pick up 1. Thanks
well guys just a update on my tvonline + sent it in and they sent me another 1, great service from them and from here thanks for the help guys.
