Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Mercenary floder2's Avatar
    yea
    fixed one today that would connect to server and show video on maybe 8 live-tv channels....Vod would kick me out if I tried to play a movie (Avov plus) by factory defaulting the box and imputing the info again .....so now live-tv and vod are working..............I think at one point in time the boxes can't take an Installer update that is needed.......but factory defaulting the box clears its head and it then takes all the Installer updates needed ...and will work again...............These updates are not the firmware update....only the installer update.....you still need to make sure you have the latest firmware build installed.........as for the Avov plus and V2 .........it should be at Version 1.08
    Sep 2016
    as
    I did a factory default, re input credentials, reset IPTV, and i am only able to connect but i cannot pull any channels nor VOD.
    Any help will be much appreciate it!
    Thanks you very much
    Problem fixed,
    I factory default one more time, and re input all the account credentials, Reset it IPTV once again and now IT WORKS!!!!
    Some channels are lagging but other than that its working!!!
    Yes I do
    Quote Originally Posted by Driver View Post
    I guess I am not alone, anybody else encountering this problem now?
    Yes my VOD section won't load
  1. Replies: 9
    Last Post: 04-06-2017, 07:50 PM
  2. Avov tvonline+ won't connect :(
    By marcus.m in forum IPTV Private Server (IPTV66)
    Last Post: 09-27-2016, 06:17 PM
  3. Avov tvonline+ won't connect :(
    By marcus.m in forum aVOV TvOnline+
    Last Post: 09-23-2016, 06:01 AM
  4. avov tvonline+ will not connect
    By wild cat in forum aVOV TvOnline+
    Last Post: 02-13-2016, 12:29 AM
  5. still it will not connect to live tv or VOD
    By LuluPu in forum aVOV TvOnline+
    Last Post: 12-22-2015, 02:33 PM
Tags for this Thread
