Results 21 to 30 of 38
  1. #21
    Quote Originally Posted by couch potato View Post
    @lino & @waynemcke:
    hmm... searching my thread here is not as hard as finding a needle in haystack (if you know what I mean )
    I feel such a fool.....Why would I look on the IPTV Stalker Install thread for the latest release when I should be looking for a 1 line download link buried away on an EPG with Genre Colour thread that I didn't know existed.
    Got the patch now. Thanks again for your help buddy.
  2. #22
    Guru
    Dec 2015
    Yes I do
    Waynemcke: Did you find the fix for the error message in this thread? The (must be integers not str) error? Starting to get a bit annoying. Thanks
  3. #23
    Patato TV
    Feb 2016
    who cares ?!
    @waynemcke
    congratz if you have found my thread here
    yes! I was in that situation too when I have to search 1 (ONE) line among hundreds / thousands ones only to find an itsy-bitsy-teenie tiny little bug
    @ADP0361
    good luck with your search
    @expatter
    >> I found that by un-ticking the items in the Features tab, the error goes away and doesn't appear to affect usage.
    yes! it's a genre filter, isn't it?
    the feature requires metadata from any movies, but mostly the server didn't suply the PPV with any proper ones and send the NULL data
    hence stalker addon read it as an error
    >> I have a request, please. Would you add the option to be able to use a locally stored epg file for any users that might generate their own grabs?
    this addon also works as an epg proxy server
    if you want to download the cmltv file, you only have to type http://localhost blah-blah-blah on your browser
    >> Not knowing python, I'm at a loss to figure this out myself.
    actually I'm a beginner too
    my basic is PHP which is rather similar to phyton codes
    >> I was able to add a 4th option and label it 'local file' and see the workings going on in the background to download the epg, but not quite sure the verbage to use to add the option for a local file option. Years ago, this is how I taught myself how to design databases, etc., but don't really have the time or knowledge to fully figure this out for myself at present.
    knowledge is the power
    no matter how old you are
    while True:
         found = search(issue)
         if found or gave_up:
               break
         else:
               gain(more_knowledge)
    if gave_up:
         buy a gun & shoot your head :D
    >> I would really like to use my own epg data, please.
    if you need a full complete epg, I suggest you to try my new addon
  4. #24
    Guru
    Dec 2015
    Yes I do
    Picture Attached. I don't have a features tab? So can't use Couch Potato's fix. How about just fixing this error for everyone.image.jpg
  5. #25
    Patato TV
    Feb 2016
    who cares ?!
    @ADP0361
    check the version of your addon
    if it doesn't show "10.3.x" then you should uninstall it and install the latest version of mine (v10.3.4-r6)
  6. #26
    @waynemcke
    Haha!!! Touché.
  7. #27
    Quote Originally Posted by ADP0361 View Post
    Yes it's in the first post in couch's thread at http://iptvtalk.net/showthread.php?1...th-Genre-Color. I uninstalled my version and then installed his latest release v10.3.4-r6.
  8. #28
    Guru
    Dec 2015
    Yes I do
    Couch Potato: Thanks for the assistance. Was able to download and set up your latest 10.3r6. Just have a question, should the guide be in Color, because I'm not getting the colored guide. Using Ninja2. Also, should I have the EPG Updater enabled? Thanks again.
  9. #29
    Guru
    Dec 2015
    Yes I do
    Just have a question, will this error issue eventually be corrected in the 10.24 version. Or something we will just need to deal with or correct on our own? I see others have had this same error appear as of late. Thanks
  10. #30
    left field
    Cool
    @waynemcke
    @ADP0361
    @expatter
    while True:
               break
         else:
    if gave_up:
    I like your philosophy and appreciate your humour. Alright, I will be the grasshopper and search for my answers. I will also use the force to expand my mind...
    Actually, my personal credo is that if I learn something new every day, no matter what it was, then it was a good day!
    Film at eleven.
    ...and thanks for the addon.
  1. Replies: 6
    Last Post: 11-13-2016, 05:11 PM
  2. list indices must be integers, not str (IPTV Stalker Video Addon Error)
    By bloodhod in forum IPTV Private Server (Rocket)
    Last Post: 09-04-2016, 03:43 PM
  3. list indices must be integers, not str
    By sfipricej in forum IPTV Private Server (IPTV66)
    Last Post: 08-29-2016, 04:28 PM
