Results 11 to 20 of 38
    I think theres something wrong with iptv stalker plus add on personally
    Patato TV
    Feb 2016
    who cares ?!
    I found the culprit of that issue
    fyi, the issue started to happen when the admin guy decided to relocate all the PPV movies into the VoD's group
    and most of them weren't supplied with some proper metadata which are required by the stalker addon to show the movie info
    sometimes the server also fails to deliver the token to the stalker client/addon in order to get its session
    hence the NULL data will cause the error when the stalker client tries to convert it from JSON to metadata
    I've just released my new addon (v10.3.4-r6) which includes the patch
    Where's the new add on
    Thanks couch!
    Ah, thanks for finding the problem couch.
    Will the new release to fix the problem be loaded onto the Install thread or is there another way of downloading it?
    Patato TV
    Feb 2016
    who cares ?!
    @dara:
    thanks for the sticky
    @lino & @waynemcke:
    hmm... searching my thread here is not as hard as finding a needle in haystack (if you know what I mean )
    Guru
    Dec 2015
    Yes I do
    Now that the error cause has been discovered, is there a correction for it yet. Tolerable, but a bit annoying. Thanks Guys.
    left field
    @Couch Potato I found that by un-ticking the items in the Features tab, the error goes away and doesn't appear to affect usage.
    I have a request, please. Would you add the option to be able to use a locally stored epg file for any users that might generate their own grabs? Not knowing python, I'm at a loss to figure this out myself. I was able to add a 4th option and label it 'local file' and see the workings going on in the background to download the epg, but not quite sure the verbage to use to add the option for a local file option. Years ago, this is how I taught myself how to design databases, etc., but don't really have the time or knowledge to fully figure this out for myself at present. I would really like to use my own epg data, please.
    Thanks in advance for your consideration.
    left field
    Quote Originally Posted by lino View Post
    Look at the first post of the first thread under [MOD].
    Guru
    Dec 2015
    Yes I do
    Can you give describe where I can find the features tab u mentioned. This error message Is not major but a bit annoying. Also noticed can't use VPN now with service, since this error started. Thanks Guys.
  1. Replies: 6
    Last Post: 11-13-2016, 05:11 PM
  2. list indices must be integers, not str (IPTV Stalker Video Addon Error)
    By bloodhod in forum IPTV Private Server (Rocket)
    Last Post: 09-04-2016, 03:43 PM
  3. list indices must be integers, not str
    By sfipricej in forum IPTV Private Server (IPTV66)
    Last Post: 08-29-2016, 04:28 PM
