was running the built in stalker client with ninja and had guide data but switched over to nfps stalker to get vod but completely nothing in guide now
why is this,,,, is there another program add I need with nfps stalker to get a guide?
So no answers here at all to this simple question hmm
Bump bump bump
Since I don't use it, I can only conjecture. If you were using EPG Updater with PVR Stalker Client, make sure it is disabled. That might cause a conflict, but I am only guessing.
Tks for reply. Yep i had disabled all that and only have nfps stalker running,,,,,,, its very strange why no guide data whats so ever now with nfps stalker,,, first time ever using it too ,,, always had built in stalker client plus ninja with guide info
yea hard to say something when not using it trying to get my tablet working again
Goto live tv settings and clear guide data then force close kodi. Restart and you should be fine.
may i ask why live has anything to do with that just for my info
System > Settings > TV > Guide > Clear data (Yes) If things are set-up correctly, the guide will usually start populating w/o exiting. If it doesn't, try a Kodi shutdown and restart.
i am having the same problem i ran away from stalker client to stalker client nfps for the vod now no epg found i also disabled the epg updater and also cleared the guide but still no epg on the other way thank god tbs is back and running do you people have any other suggestions ??
