Results 1 to 9 of 9
    TV Junkie 1sikguy's Avatar
    Apr 2016
    Limbo
    Post Problem setting up MAC on Stalker Plus addon
    Setting up Stalker Plus addon...
    MAC is set up with xx:xx:xx using the last three pairs of the MAC addres I use for Stalker Client setting. Stalker Client is currently up.
    Getting error message : Custom MAC 3/2/1 is invalid
    Can Stalker Client be running at the same time as Stalker Plus addon, or does Stalker Client need to be off?
    They should not be running at the same time. Beyond that, you have prior MAC addresses that are conflicting with the IPTV Stalker Plus set-up. So...
    Disable PVR Stalker Client. Set Defaults in IPTV Stalker Plus. Make sure all portals show 00:00:00 as the MAC addresses. Re-configure IPTV Stalker Plus. Now, disable IPTV Stalker Plus. Go to the Donation Checker and do an IPTV Reset. Enable IPTV Stalker Plus and it should be up and running.
    Apr 2016
    Limbo
    All fixed and working now... much thanks
    Jul 2015
    I am having the same issue with rocket donation. Followed all the steps for invalid Mac URL but it still says invalid. Help please..
    You are trying to set-up IPTV Stalker Plus? What is the error message? The one you mentioned doesn't strike a bell. Did you follow the directions I mentioned above (to the letter)?
    Jul 2015
    I am. I'm getting Custom MAC 1, 2, 3 is invalid when doing all the steps you mentioned...
    You need to open IPTV Stalker Plus and click Default. Now disable IPTV Stalker Plus and close Kodi. Do an IPTV Reset at the Donation Checker. Open Kodi (do not enable IPTV Stalker Plus yet). Now enter the credentials in IPTV Stalker Plus. If it has been at least 15 minutes since you did the IPTV Reset, enable IPTV Stalker Plus and you should be good to go.
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    And make sure your MAC prefix is 00:1A:78, not 79.
    Jul 2015
    I did exactly so. My IPTV URL is 22 so I used 00:1A:78.
    "Custom Mac 1 is invalid"
    "Access denied"
    When including a custom info, device ID, signature, etc:
    "List indices must be integers..."
  1. Problem with Addon
    By DonaldS in forum Kodi Discussion
    Last Post: 11-28-2017, 08:15 AM
  2. Replies: 2
    Last Post: 01-21-2016, 03:53 PM
  3. Setting up channel icons when using IPTV simple client + Stalker Video AddOn
    By mephasor in forum Kodi Tutorials, Tips & Tricks
    Last Post: 11-10-2015, 01:05 AM
  4. Stalker Kodi addon vs PVR addon
    By d3rider2k5 in forum IPTV Private Server (NFPS)
    Last Post: 07-24-2015, 07:49 PM
  5. I am AN OLD TIMER having a problem setting up WIFI...
    By 1932ford in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 03-24-2015, 01:00 AM
