Results 1 to 10 of 14
Thread: Help
    Help
    Is anyone else having issues with their TVonline box. Everytime I going into live tv, it boots me out and brings me back to main menu
    Aug 2016
    I am having the same issues. my box updated and then poof
    Mercenary floder2's Avatar
    yea
    Yes.....I'm having same problem...........Connects to server go's to live channels but immediately sends you back to the main menu of the box........Same with VOD
    all started after the installer update............Now the box has been unplugged and rebooted multiple times.........router and modem has been rebooted..............The box has no problem connecting to server...........just the VOD and Live Tv...won't work as described above
    Just tried my avov plus and it's working fine. I'm assuming it's just the avov TVonline having this issue.
    yea
    Seems that way.....hope this is not Avov's way of making this original TV-Online box Obsolete .........So they can sell Newer Boxes.............
    i don't think so, I was told that server is updating and they will send a new update that will fix this issue.
    crazybobs TV Expert
    I hope your right
    All AVOV TV Online. Plus & Version 1
    I factory reset and also soft reset 3 versions of the AVOV and still same result on 11
    yea
    bwcbob.........did you say in another post your tv-online plus took an update and is working ?
    I have the plus and silver edition, there both working. Only one that isn't is my tv online version 1
    crazybobs TV Expert
    Quote Originally Posted by floder2 View Post
    yes I did on server 22
