My gica is pretty legit... no lag and also pretty fast!
Hi, the Minix Neo x8-h is more expensive than the AVOV 2. Is the difference worth paying? I am considering either.
Spec wise they are about the same the minix has an extra gig of ram. I used to use the minix but moved away because I wanted a device that is specific to IPTV and that can do kodi. I would suggest the AVOV over minix but check out the TVONLINE 4 box it has better specs and is available for purchase now.
Well, I've decided to update my original post on this since I've changed a few boxes since then and my favorite IPTV android box would be a Nvidia Shield TV 16gb or basic version as it has a whole lot more and a whole lot more hardware power to do it. I have the AVOV Vixo 2 which also comes with free games and a controller but its not in the same league and it doesn't have the hardware, ports or graphic engine and memory to be on par with the Nvidia box. Downside, the Nvidia is about double the cost so it comes down to what you want and how much. I ordered the AVOV TVonline4 box which has a 2ghz processor and Bluetooth 4 but it comes up short with the older T10, T100 ethernet port and USB 2.0 ports. As for the graphics, its too early to tell but it will be tough to match Nividia's Tecra graphics and its frame rates per second on Ultra HD / 4K.
The Nvidia Shield comes with free games, Kodi, Google Playstore, ( but limited apps similar to AVOV Vixo 2 & Mickeyhop). Nvidia box doesn't have a hard reset, just a software reset which makes a locked up box harder to get back to factory default.
hi all, i am interested in an IPTV sub. and I need to buy an IPTV box. The MAG254 seems to be the preferred choice for IPTV with the providers in my country but I would like a box with the possibility of installing Netflix, Youtube and Kodi, which I understand is not possible with a MAG box.
Would I suffer from lag/buffering if I choose another box or are there other options with my requirements still up to the task? If yes, which box would you suggest? Thanks
At this point in time, is the mag 254 still the best box if you want just IPTV? I see there are newer models of Mags now? Which is better?
the 254 never fails me
you gotta watch the Mag receivers, some are for strictly networking situations, like a college network or etc
The 272 models are like that i think.
I could be wrong, but in fact the Mag boxes are not all the same
