1) Start Kodi, when channels load
2) Right click over the channels
3) Find Group management option, click
4) Click add group, then name
5) Select the channels you want, then click OK
6) Return to main channel screen
7) move cursor to left of screen
8) Under view option select Group
9) Select group you just created... done
May have options similar to these for your boxes etc... Not sure
