Results 1 to 10 of 10
    Jul 2016
    stb emu problems
    hi guys ...looking for some help if possible ...i have a subscription for my tv payed on iptv66... using he stb emulator and it stopped working yesterday so i updated to the latest version on the google store ... but same story ...all it says is " please contact your provider to register this device" can anyone advise me what to do or has anyone else had the same issues
    Apr 2015
    Crusty 197 when contact service provider comes up, I just go into Papio.TV Donation Checker and do an IPTV Reset go back to stb emulator click on my profile and enter my username and password using the onscreen keyboard exit. out enter my username and password again and it works. Don't know why you have to do it twice but it works, I'm using version 0.8.05 and everything is working great. I hope this helps sader5.
    Oct 2015
    Quote Originally Posted by sader5 View Post
    How did you get to the username and password screen? I found it a few times when I first started and am now unable to find it again...
    Kill the app and re-open. That should bring up the right screen to enter username and password...
    Oct 2015
    Quote Originally Posted by mrgreg View Post
    ok.. I was gonna uninstall it then re-install it hoping that might fix it...
    Apr 2015
    glen 1971 go into the menu on the left side of the screen click on change profile data look for advanced settings click on that then look for apply CSS patches and enable it exit out and look at my earlier post above and you should be good to go, providing you got the Server info and Mac info. hope this helps you out, sader5
    Jul 2016
    yes I do
    Good Evening everyone, I have a subscription to iptv66. A few weeks ago I lost all VOD and PPV. Is there something I can do to get it back?
    Oct 2015
    I enabled it in one of the first steps after uninstalling and re-installing it... Got to the password/log-in section and can't seem to enter anything.. Get an error..And that's where it sits...
    Apr 2015
    glen 1971 you have to use the keyboard on the top right menu to enter the password then use the down button onscreen to get to next line for password then the down button and hit OK button if the blue barber bar goes yellow a 1/4 of the way exit enter the username and password again and it will work. sader5
    Oct 2015
    Thanks a million!!! That got!!!! It took twice to get it like you said and now it seems to have loaded!
  1. VOD problems
    By gangstaIP in forum IPTV Private Server (IPTV66)
    Last Post: 05-28-2020, 05:01 AM
  2. problems
    By billyg in forum IPTV Private Server (Rocket)
    Last Post: 06-05-2017, 03:10 AM
  3. New guy-problems
    By Nabil in forum Chit Chat Lounge
    Last Post: 11-06-2016, 05:23 PM
  4. having set up problems
    By hog1945 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 07-23-2015, 10:15 PM
  5. epg problems
    By timezone12 in forum IPTV Private Server (Rocket)
    Last Post: 07-18-2015, 05:07 PM
