Results 1 to 5 of 5
    Jun 2016
    IPTV66 work with SimpleIPTV through IPTV Stalker Plus but Authn fails with Stalker
    Im using IPTV66 with a passthrought from IPTV Stalker Plus to IPTV Simple and works fine but when when Kodi shutdown sometimes i have to restart the mu3 server or clear data because only one channel show twith an error, so i decided to give it a try to the buildin stalker client and even using peg.ninja i keep getting authentication failed, so had to go back to simple iptv, why is this error with this one app ??
    Jun 2016
    Are you entering your login info in the epg ninja only? Do not put any info in the pvr stalker configure section. Only put your info in the epg ninja configure section. Disable the other PVR addons, other than PVR Stalker. After doing that, reset your iptv from your donation site. Then reboot Kodi, Enable TV in the TV settings area. Channels should load then.
    Jun 2016
    Quote Originally Posted by stratt197 View Post
    im sure i tried that way, ill try again, i wasnt provided an iptv site only a login, password and my mac, for the mac should i use the whole mac or the last 3 hexs only like on stalker plus?
    Jun 2016
    Quote Originally Posted by fokeiro View Post
    You should use the entire mac address. Someone else would have to comment on the Server address for 66, as I use nfps.
    Jun 2016
    Here is the link for Psycon's instructions.
    http://iptvtalk.net/showthread.php?1...=stalker+ninja
  1. What to use now iptv stalker plus does not work help
    By tom520 in forum IPTV Private Server (IPTV66)
    Last Post: 03-28-2017, 10:54 PM
  2. IPTV Stalker just wont work........Help
    By galahad in forum IPTV Stalker (Video add-on)
    Last Post: 05-23-2016, 11:08 PM
  3. Stalker IPTV Android won't work
    By MTBv01 in forum IPTV Private Server (NFPS)
    Last Post: 02-07-2016, 12:53 PM
  4. Mag TV- Stalker IPTV Emulator doesn't work ?
    By maxidreamn in forum IPTV STB Emulators
    Last Post: 01-07-2016, 01:20 AM
  5. Setting up PVR to work with IPTV Stalker
    By moorsean in forum PVR Clients
    Last Post: 09-24-2015, 05:05 PM
