Results 1 to 6 of 6
    Jul 2016
    Mag254 Remote issue - please help friends
    Hi friends,
    I have brand new Mag254. sometimes when i turn on box with remote it wont turn on. i have to reset the power cable from the box. i have noticed that when i am pressing power button on remote, red light blinks on remote but on box blue light doesn't blink. so i thought it was bad box so i got replacement and now new one is doing exact same thing. is there settings on mag254 i need to change?
    please help me friends
    thanks
    tester
    Yes I do
    here is the fix for that try this To reset:
    Press SETUP and OK button at same time and hold for 2 seconds red LED will flash 5times. Reset is done
    Nov 2016
    I have a question, how can I move up-down the programs with the remote of mag254??
    Dec 2015
    Yes I do
    Quote Originally Posted by Zemrije View Post
    Hi Zemrije,
    You can make that change from the "Up & Down" arrows around the "Ok" button; or from the "Chan" (+up/-down) button..
    Good luck!
    Nov 2016
    Thank you very much, but I didn't make good the question..
    I'm interested of changing the number of program to make my own preference of programs for example: CNN is on 256channel I want to remove at 15channel, to be easy for me to find the program, so I want to make a change at program numbers, but I don't now how can I make that..
    I hope that I'm clear of what I want and, sorry for the mistakes because I don't know very well english, thanks!
    iptv
    The only option you have is to create a favorites list and put the channels you want in the order you like
  1. last channel remote issue?
    By curgs in forum BuzzTV XRS4900
    Last Post: 05-24-2022, 09:49 PM
  2. Remote control issue
    By kronic187 in forum Dreamlink T1 Plus
    Last Post: 12-24-2017, 07:06 AM
  3. I got a issue with remote
    By ali131 in forum aVOV TVONLINE 4
    Last Post: 07-04-2016, 11:05 AM
  4. remote issue
    By brijshit in forum aVOV TVONLINE 4
    Last Post: 06-21-2016, 04:12 PM
  5. Remote issue
    By Breclear in forum Kodi Tutorials, Tips & Tricks
    Last Post: 10-31-2015, 10:08 PM
