Results 1 to 10 of 12
    Question blue led light but no signal?
    I set up my mag 254... it was working fine.. then when I got home from work, only the blue led light is on but my tv says no signal.. I have tried different hdmi cable and av cable.. also tried a different tv... but same result.. even when I connect the power only the light comes on.. and tv says no signal..
    Any help is appreciated
    Ambassador DarkSide's Avatar
    If your tv is on the right input and still nothing you might have to reset the mag from the bios menu
    http://iptvtalk.net/showthread.php?5...reset-your-box
    I tried that already DarkSide.. and still does nothing....like if its not even connected
    Android World
    If you have another power supply adapter from the same model iptv box try to swap it see what happens.
    Tried that and nothing... seems like the box just went bad...
    Member ZurichKabel's Avatar
    the box pops into IDLE mode after min 1 hour ,just reboot...
    Android World
    Quote Originally Posted by ZurichKabel View Post
    He had tried that as well above.
    Member EPAPRESS's Avatar
    Besides that problem: You are able to set the brightness of this blue LED on MAG 254 (r11):
    Select Portal for loading > Embedded Portal > Settings > Interface > 5x Down > LED brightness: (0-100, normal: 10) > LED brightness (standby): (0-100, normal: 100)
    Manfred
    Thanks for all your help... just sent it back and getting a replacement
    Jan 2016
    yes I do.
    Quote Originally Posted by jrgama61 View Post
    I am having the same exact issue. I can't connect via hdmi or rca keeps saying no signal.
    Mag254 has power and confirmed hdmi input works still nothing. It was working fine last night.
  1. m8s+ no blue light HELP
    By etnies in forum OTT M8 4K Android TV Box
    Last Post: 06-26-2017, 07:54 PM
  2. M8 Flashing Blue Light
    By donaldb in forum OTT M8 4K Android TV Box
    Last Post: 05-14-2017, 04:38 AM
  3. Only red & blue light on box
    By cowboy in forum AVOV IPTV Boxes
    Last Post: 02-24-2017, 12:58 PM
  4. Mag254 blue power light but no signal
    By NICK1286 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 12-04-2016, 01:15 AM
  5. Mag 254 No Blue Light! Please Help!
    By arman00 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-15-2016, 02:36 AM
