Results 21 to 30 of 31
Thread: Avov tvonline 4
  1. #21
    Between 9 and 10 pm eastern time a fix will come out thats from them
    It will be a file
    to run through a USB
    thats for the ones with the 1.0.6 problem only
  2. #22
    Jun 2016
    It will be a file
    Will this work for me and where do I download from.
    Since i have a black screen how do I install and run this file !
  3. #23
    bry bryb
    Jul 2015
    Thanks a good question.
  4. #24
    all i know it will be a usb file you put on a stick and reboot were is it all i know is what they said so i pm them about were is it could be on there site
  5. #25
    Jun 2016
    I finally got a reply from them to my ticket of 6/20 asking for image of screen display. I have submitted that just now.
  6. #26
    http://avovtech.com/2016/06/23/how-to-fix-tvonline4k-v1-0-6-boot-issue/
  7. #27
    Jun 2016
    I downloaded the file onto a usb and stuck it into the unit and followed the isntructions. but no luck.
    The unit does not recognize the USB or it shows up blanl. but the file is there as it pulls up when i use my pc. see vide clip on utube https://youtu.be/fyu7S5IYpww
  8. #28
    i see the ext you need to use use remote to high lite that and hit ok
  9. #29
    Jun 2016
    Thats what I did. exactly as per instructions on their website. When i do that the USB has light and that blinks but the TV4K unit does not recognize the data in the USB, I reformatted the USB using my PC and downloaded the File again from the avov website but same result the box cannot recognize the data in the USB
  10. #30
    Jul 2015
    yup
    Usb needs to be formated to Fat32
  1. AVOV TVonline+
    By a-team in forum aVOV TvOnline+
    Last Post: 03-22-2016, 01:52 PM
  2. APK for Avov tvonline+
    By Jadaca in forum aVOV TvOnline+
    Last Post: 12-16-2015, 12:50 PM
  3. Avov tvonline
    By OMARKAYAN in forum aVOV TVOnline
    Last Post: 12-12-2015, 07:32 PM
  4. Avov TvOnline vs Avov Vixo 1
    By master10 in forum aVOV TVOnline
    Last Post: 05-19-2015, 12:47 AM
