Results 1 to 10 of 14
    Help with preview Box to work while surfing using MX player
    I know that there are a lot of post concerning this topic put there are not any post with step by step instructions on how to do it, i'm using MagTv and Mx Plyayer 17.37, mx player codec armv7. and I still cannot get this preview thing working for me, can anyone help me and other with this?
    Any help would be appreciated.
    Thank you in advance..
    Ambassador DarkSide's Avatar
    are you trying to view the channel in the preview box? i have not seen that work with the mx player
    Oh, ok thanks DarkSide, could you recommend any player that work with preview box working with magtv?
    The preview box only works sometimes with the internal player or the VLC plugin settings. I can't say if it works with "MagTV" or the "MAG 260", but it works sometime on my android and PC emu's.
    Forgot to mention I'm also using Migica 1200..
    the mag 260, it does work on the internal player but its hit and miss.. sometimes it will work, then it wont, then nothing works... Same thing with my MXIII and the M8... i have never seen it work with the mx player, im hoping one of these updates to the emulator will allow the internal player to work as it does on the mag 254
    Would you recommend internal Player??
    you can try it out... internal is just real up and down.. sometimes the movie plays, sometimes not, same with live tv.. it wont hurt to try it, you can always go back and change from internal to external if it doesnt work.. i always try the internal when a new version of the emu comes out and always have to end up using the mx player, which is fine, cause it works well
    Thanks again, I think I will stick to Kodi with MyGica, it seems to work better, I did notice with Kodi all Adult stuff is gone..
    IMO, kodi works better than the emulator, but at this time with all the channels that have been added, not all of them work... We have to wait for an update to the stalker addon for the new channels to work
  1. Does M3U work with the Tv Online player?
    By Biglo in forum aVOV TVONLINE 4
    Last Post: 03-05-2018, 05:12 PM
  2. Channel Preview
    By Raj909 in forum Amazon FireStick & FireTV
    Last Post: 02-13-2017, 08:26 PM
  3. Preview Screen
    By JJ8964 in forum IPTV STB Emulators
    Last Post: 08-24-2015, 01:46 PM
  4. Replies: 14
    Last Post: 02-20-2015, 09:42 PM
  5. STB Emulator and channel surfing ......
    By Mr.Noodle in forum IPTV STB Emulators
    Last Post: 02-08-2015, 02:42 AM
