Results 1 to 4 of 4
    Hard Wired Vs Wireless
    Has anyone recognized that this box seems to work flawlessly when hard wired but over WiFi its totally sticking and it wont even locate my 5.0GHz signal even though they are in the same room. Is anyone having this problem?
    all i use is wireless and np at all but i have one of the best wireless router and i run 6 boxes at time
    get active
    Quote Originally Posted by shambala View Post
    I don't know of any AVOV box that is equipped with 2.4 / 5ghz AC wifi. All AVOV boxes have 2.4ghz only which may explain why your box doesn't see any 5ghz wifi bands including yours. If you want wifi, go with 2.4gzh and set your box up on it, otherwise, hardwire it.
    Please understand, the ethernet port only provides T10 and T100 speeds or throughput, it is not a gigabyte port which provides T1000 service so it too is limited.
    Mar 2016
    Courss
    Technically hardwired is better for any device. But haven't had problems with the wifi. I have a wifi range extender really close to it to give it full strength but even the 2.4ghz works great even on 1080p quality on kodi and another provider I can't mention
  1. no wired connection
    By xayoz in forum Formuler Z7 & Z7+
    Last Post: 05-09-2019, 01:32 PM
  2. Wired t1 plus crash network
    By alex36 in forum Dreamlink T1 Plus
    Last Post: 11-01-2017, 11:21 PM
  3. Xbox 360 wired controller on M8S possible?
    By neochux in forum OTT M8 4K Android TV Box
    Last Post: 01-08-2016, 07:50 PM
  4. wired internet
    By floder2 in forum aVOV VIXO1
    Last Post: 03-02-2015, 03:06 PM
  5. Replies: 8
    Last Post: 01-18-2015, 05:17 PM
