just got tvonline4 very easy setup the only problem is that i am having is nova setup does not work for me follow instruction
if you get page where it says login it them or your info was wrong sent to them and you did the url in server two and connected
i put correct url in this one in server 2 66.85.29.47/nova/client what mac do i use the one from in server settings
thats all you do and connect it
thanks asft
you did send them your info right on that web page http://iptvtalk.net/showthread.php?1...va-beta-tester
yes i said info just waiting asft for them
tvonline4 is very nice box but it needs updates the vpn in settings dont work cant load side apps on the box i hope they fix the problems
ones from here should workCode:http://mhaddons.com/login.php?do=login
