Try the hard reboot like you suggested wickedjoker and nothing .. Is there an update I can get to put on and you a usb and instal it manually
Honestly it sounds like there is an issue with the box I would contact AVOV and get a replacement.
Code:https://help.avovtech.com/portal/newticket
Ok I will reach out to them and see what they have to say
other thing it could be is there server is down to update but if you get half way and then it stop i would say talk to them like wickedjoker
Two updates came out back to back, 2nd was for the Tuners (I think mainly satellite). Mine was stuck too, i exited it, hard reset, and then it booted, updated and now is ok.
