Results 1 to 4 of 4
    Member Cd001111's Avatar
    Jun 2015
    Yes I do.
    Won't connect using Ethernet
    When I first started using a Avov TV online box about a year or so ago it just wouldn't work using WIFI, it keeped buffering & freezing, I switched to an Ethernet wire & it solved my problem until last Saturday. I was actually watching a movie using KODI when everything froze, the Avov box lost Internet connectivity. I did reboots on everything but it wouldn't connect, Next I connected it to my WIFI with no problem and to my surprise it works just fine, way better than when I first got involved but it won't connect using the Ethernet wire, only WIFI. I would love to go back to using a wire because it's all there already, if anyone has any thoughts I'm all ears.
    Mercenary floder2's Avatar
    yea
    Had that same problem once and had to factory default the box to fix the Ethernet problem,,,,,,,,,,,,,,,,,
    Jun 2015
    Yes I do.
    Quote Originally Posted by floder2 View Post
    Thanks much
    but when you do that the package must install you will see box pop up and that will tell you your fine
  1. wi-fi to ethernet
    By bones65 in forum BuzzTV 3000 series models
    Last Post: 12-05-2018, 09:09 PM
  2. How to connect Dreamlink T1 Plus using wired ethernet?
    By ms253t in forum Dreamlink T1 Plus
    Last Post: 10-29-2017, 10:12 PM
  3. Mag 254 100mb ethernet
    By Deathball in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 10-31-2016, 12:54 PM
  4. mag to sky q ethernet
    By TigersCas in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 08-12-2016, 04:28 PM
  5. Have internet and ethernet
    By bearwithme in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 04-01-2015, 11:09 PM
