Hi all,
Thanks for the great forum.
My T1 had sound few days ago...now none of the channels have sound ?!
Help please.
montell
Hi all,
Help please.
montell
Just throwing this bc it happen to me, is the volume up on your T1?
Check the HDMI cable, connections?TV mute button?
Everything checked fine...still no Sound ?!!
Factory Reset would be an option!!!
what will I lose when I do that?
everything?
I had a similar issue with my mag on a LG tv I had to unplug the HDMI from the box reboot it and restart the tv once both came back online i plugged the device back in and it worked fine. I still have this issue from time to time so you can give it a try see if it works for you.
Also are you running this through a sound amplifier or direct to the TV?
OMG!!! I bought another remote (Mele) and had the dongle in usb on T1.....as soon as it took the Mele dongle out...Voila!! Sound is back
Many thanks guys for your generous support...you guys rock
montell
