Page 13 of 13 FirstFirst ... 3111213
Results 121 to 123 of 123
  1. #121
    Super Moderator at Work theone's Avatar
    Portal 22 is up and running so there is no need to continue with this thread and please DO NOT disrespect the service, you are entitled to your opinion but disrespect is not allowed.
  2. #122
    I'll check the 22 portal using the 78 prefix... If it doesn't work, I'll reopen the thread.
  3. #123
    IPTV Stalker does work with the 00:1A:78 prefix on my 'testing' version. Still not verified if the "Token" is required to be sent to the server for the addon, or for the PVR.
    PVR Stalker works with the 00:1A:78, but doesn't require the token field ... using the same credentials from IPTV Stalker. (SN, Device ID, Device ID2 and signature, empty token).
  1. portal p1.iptvrocket.tv
    By jta623 in forum aVOV TVOnline
    Last Post: 03-09-2018, 03:13 AM
  2. Portal p1.iptvrocket.tv not loading
    By mwhoody in forum IPTV Private Server (Rocket)
    Last Post: 02-22-2018, 02:51 AM
  3. portal http://p1.iptvrocket.tv
    By remmirt in forum IPTV Private Server (Rocket)
    Last Post: 08-18-2017, 02:17 PM
  4. New portal url: 22.iptvrocket.tv
    By dara in forum IPTV Private Server (Rocket)
    Last Post: 05-19-2016, 09:40 PM
  5. portal 11.iptvrocket.tv
    By alpogie in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 04-20-2016, 12:32 AM
