Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Guide Is Blank
  1. #21
    You can try to make the change mentioned above or wait for the next guide update, which will hopefully fix the issue.
  2. #22
    Adding the tag mentioned fixed mine on kodi 16.1 win 10. Hope that helps someone.
  3. #23
    Nov 2015
    yes i do.
    Quote Originally Posted by expatter View Post
    Here's a fix for the blank guide:
    open the epg_xmltv.xml file with an editor (like notepad++, etc) and scroll to bottom line and cursor up one line; you will be here:
    </programme>
    </tv>
    Insert a new line between these two lines and add the following: </programme>
    It should now look like this:
    </programme>
    </programme>
    </tv>
    I know, it seems counter intuitive, but it worked for me!
    Save the file
    Go to Kodi settings for TV and under guide, clear data (not for TV, just for guide!)
    Guide will load up!
    Cheers.
    is thare any spaces my format in notebook puts it like </programme></tv> not bottom to top
  4. #24
    There are no spaces. If added, they would be disregarded.
  5. #25
    Apr 2016
    where to find that file????
  6. #26
    Mar 2016
    yes I do
    Guys all these quick fixes are just temporary solutions. Do we have any idea if the actual fix is being worked on?
  7. #27
    left field
    Today the UK section was blank and I find a partial guide bothersome, so I ran the Ivue guide addon and then went into the addon directory for it and opened the master.xml file, then highlighted and copied the whole thing; then opened the epg_xmltv.xml and pasted the Ivue guide at the bottom of the ninja guide. I had to clear the TV guide data twice, but that pretty much filled the entire guide in after that.
    It's another temporary fix, but...it's a full guide.
  1. what happened to Stalker PVR Guide? Its all blank
    By infectedtrut in forum IPTV Private Server (NFPS)
    Last Post: 06-15-2016, 08:12 AM
  2. Blank guide
    By kroakie1 in forum EPG (epg.ninja)
    Last Post: 05-24-2016, 07:34 AM
  3. Epg guide blank
    By Chrisss in forum IPTV Private Server (IPTV66)
    Last Post: 05-14-2016, 08:43 PM
  4. Guide (Mag254)- Mostly Blank
    By Aids10 in forum IPTV Private Server (NFPS)
    Last Post: 05-14-2016, 05:47 PM
  5. STALKER PVR Guide is all blank
    Last Post: 09-21-2015, 06:25 PM
