I made donation for rocket last Friday.
I cant conect not with Magtv at Mygica 1800E .(blue nar at 25 %) or with iks.
Is there someone who can help me with this.
Don't know with out your settings we can just guess.
which settings do you need to know?
Don't post the donation number but use *** for that and all the other settings for the server!
IPTV PORTAL: 11.iptvrocket.tv
IKS SERVER: 6.rocketserver.tv (Dish)
PORT: 35966 (Dish)
DESKEY: 6103403445406970987123412134
STATUS: ACTIVE
As long as you use the donation for user/pass you are good to go.
Depends what you want to use. If you are using Kodi, the built-in PVR Stalker client will connect you. Use the 11.iptv... address when configuring it, although you may have to use the longer address mentioned in the instructions that are detailed below...
http://iptvtalk.net/showthread.php?1...et-up-tutorial
Thanks for help.
I have connection now.
I can connect now with Magtv at Mygica 1800E .
I download latest version of MagTV from mystore.
Also I change device ID to true and allow magtv to send that info to portal.
It looks was my problem all the time .
Regards,
Marko
