Results 1 to 4 of 4
Thread: Mag275 help
    May 2016
    YES I DO
    Mag275 help
    Hello.....
    im faiRly new to this, but here it goes. I have a mag275 i bought a donation with iptvprivateserver.tv
    i follow all the instructions and it's a been a month i try to connect my box with no luck. I put the the address in the portal, i use my donation number and all it does is tries to load n it stays there. WHAT CAN I BE DOING WRONG?
    or what else can i do? CAN ANYONE HELP ME. PLEASE!!!
    wickedjoker wickedjoker's Avatar
    Starkiller Base
    Hi Jelissa sorry to say but the 275 is not compatible with NFPS per papaio. Maybe one day they will fix this but at the moment it is not they suggest using an emulator to get around the issue.
    "Hi.
    Sorry for the inconveniences at this moment MAG275 boxes are not supported, you need to use an emulator.
    To receive the corresponding assistance with the following points please visit our forum
    Configuration instructions.
    Technical Support.
    Compatibility Inquiries.
    Best regards,
    Papiao.TV Staff."
    May 2016
    I am also having same problem with my stb emulator. Screen at loading all the time after inputting login and password. Please help
    Starkiller Base
    Agyare please start your own thread for this issue.
  1. Replies: 7
    Last Post: 07-11-2015, 05:52 PM
