Results 1 to 2 of 2
    May 2016
    HELP! OTT TV Box S905 4K - missing recovery mode
    Hi all,
    Play Store in the original firmware did not work so I had to flashed it with another ROM.
    Now I cannot not get into the Recovery Mode using the tooth-pick method (>30 sec press). It went straight into the Android main menu. It looks like the box lost this function after I managed to flash it with the Geekbuying firmware for this MXQ Pro box. The box seems to be working OK with a few quirks but it lost the ability to get into the Recovery mode.
    Is there a way to restore the Recovery mode?
    The original ROM: "ro.build.description=p201-userdebug 5.1.1 MXQ-Pro 20160413 test-keys" and I have not found an old or newer ROM that worked 100% with it
    Board version: MXQ_S905_V2_0_2015112
    Thanks.
    alphaaaaaaaaa alphablondy's Avatar
    see if you can go into Settings & do a factory reset. it should return the box to factory condition.
  1. Thanks for the quick recovery
    By Tubbs in forum Helps us Improve!
    Last Post: 10-04-2019, 02:53 AM
  2. Recovery instructions
    By crazed 9.6 in forum Formuler Zx
    Last Post: 11-13-2018, 03:41 AM
  3. Recovery instructions
    By crazed 9.6 in forum Formuler Z7 & Z7+
  4. Replies: 0
    Last Post: 03-02-2016, 07:37 PM
  5. How to recovery Password
    By usphil in forum IPTV Private Server (NFPS)
    Last Post: 02-03-2016, 12:43 AM
