Results 11 to 20 of 24
    asft, I manage to install installed kodi-14.1-Helix-armeabi-v7a-stalker-0.5.apk on mygica but lost all my tv addons copied all addons back to my data file back to my box but they did not work, am I doing something wrong? and if I install Mag TV will I loose all my favorite TV Addons?
    what are you talking about the magtv app will be application thats why i said use that it made only for this box only thing you need to do is install it from google play store which is in application install it then install mxplayer click on magtv load the 1.iptvservertv some thing like that go out click app again when in stalker bottom or right on page click on use mxplayer thats it now have vod and livetv working and yes if you made favorite TV Addons will lose that will be new stalker if you are talking about live tv ones in stalker why not use something that is made only for this box i dont get it why use kodi-14.1-Helix-armeabi-v7a-stalker-0.5.apk on mygica when magtv works better
    ok asft, I will, thanks again..
    OK, I managed to get Stalker installed on Mygica but DLL error, I tried reading how to fix but I cannot find any step by step to do that any help would be appreciated, using Kodi 14.2.
    I am consideration but not sure if I will loose all my setting and addons I have installed??
    Thanks again..
    Quote Originally Posted by jimmybrown57 View Post
    Thanks again..
    The only tried and true solution to the DLL issue is to completely uninstall your Kodi, and re-install using the modified apk available on the Stalker PVR Client thread. You will lose all your settings and add-ons that you previously installed, though, and even though you can retain them through a backup, restoring those are kind of a pain if you don't know your way around the android file structure. I'd take asft's recommendation to stick with the STB emulator specifically for the mygica, if you aren't up to blowing away your installed Kodi.
    Here is the link from that thread:
     https://mega.co.nz/#!mVpVBABZ!Kj_F6aQVefbxcmASRnEJTpON9S7n1ulR10yrjJtjpco
    I agree with Asft..stick w/ the mygica app
    Sorry, this is probably a stupid question but I do need to ask will I be able to use kodi after I install magtv ?
    did you read its app not on kodi at all has nothing to do with it at all
    no, sorry, I still trying to understand all the lingo, I did install magtv and mxplayer but cannot seem to get it to work!!
    how do I load the 1.iptvservertv into magtv??
  1. MyGica-Kodi 17.3 &Stalker Client 2.8.8
    By 1944 in forum MyGica Android TV Box
    Last Post: 06-11-2017, 12:12 AM
  2. mygica 585 and mag tv
    By DRDP in forum MyGica Android TV Box
    Last Post: 09-12-2016, 03:16 PM
  3. MyGica ATV 1200 Kodi 16 Jarvis
    By jimmybrown57 in forum MyGica Android TV Box
    Last Post: 08-04-2016, 05:44 PM
  4. Mygica ATV 1200 Kodi IPTV
    By space_114 in forum MyGica Android TV Box
    Last Post: 05-04-2016, 05:09 PM
  5. My Gica 1200
    By stoner66 in forum MyGica Android TV Box
    Last Post: 02-10-2015, 04:27 AM
