Results 1 to 3 of 3
    Apr 2016
    Best kodi addon for sports channels - Adrian Sports
    Hi guys in this new thread i'm going to show you how to install one of best kodi addons for live sports channels in my opinion, this addon called Adrian Sports.
    So let's get started install this addon :
    -- Open kodi and go to system > File Manager
    -- select "Add Source"
    -- Click on the <None>
    -- Type this source :
    http://communityrepo.comlu.com
    -- Click on The "Done"
    -- And then enter a name for this source asuch as 'commrep'
    -- Click on the "OK"
    -- Now back to kodi home, and select "SYSTEM"
    -- Select "Add-ons"
    -- Select "Install from zip file"
    -- Select "commrep"
    -- Then select ".TheCommunityRepo (click here)"
    -- Select "repository.communityrepo-2.0.zip"
    -- After see addon notification go to "Install from repository"
    -- And select "repository.communityrepo-2.0.zip"
    -- Then "Video Add-Ons"
    -- select ".ADRIAN SPORTS."
    -- Click on the "Install" and wait a moment
    Now Adrian Sports has been enabled, go to Videos > Add-ons > Adrian Sports from kodi home screen And enjoy !
    See you next time with other kodi addon
    All the best
    If you are looking for a VPN for Kodi, i recommend you using IPVanish VPN: https://goo.gl/8jEpjy
    IPVanish is one of the best VPN clients because it is tier 1 (no speed slowdown) and log-free so that you are protected. The cost is about the same as a Starbucks coffee per month. Sign up with this link: https://goo.gl/8jEpjy and get 25% off any VPN Plan with IPVanish VPN.
    I use IPVanish VPN to protect my online identity and to access all my favourite Kodi addons.
    Bulletproof
    This addon is closed down ??? What happened ?
    Apr 2015
    It used to have a good HD feed with no buffer. But that stream is gone. Its hit or miss, feeds are up sometimes and sometimes down.
  1. Kodi Sports Addon Returns: Moneysports
    By Kimbo in forum Reviews
    Last Post: 11-25-2016, 02:51 PM
  2. Replies: 0
    Last Post: 10-24-2016, 09:23 PM
  3. Best kodi addon for sports channels - Kodi Pro Sport Addon
    By Tom-Las in forum Addons & Repositories
    Last Post: 04-26-2016, 02:51 AM
  4. Best kodi addon for live sports channels - Sports Mix
    Last Post: 04-24-2016, 08:37 PM
  5. How do I find Sports devil on Addon on Kodi?
    By chal2000 in forum Kodi Discussion
    Last Post: 08-28-2015, 03:32 PM
Tags for this Thread
