Results 1 to 4 of 4
    Oct 2015
    you have to say yes i do..
    Lightbulb Freeze when not changing channels
    Has anyone found a solution to the freeze that occurs when you don't change a channel for a while? Sometimes its 15min sometimes it's an hour. Basically it would appear as though the connection to the server times out. If I channel up and down the service and channels become viewable again.
    Jan 2015
    I was wondering the same thing. I can watch a 1/2 hour show and sometimes a 1 hour show but that is it. If i try to watch a 500 channel i cannot get through the entire show. I looked back in the thread and only found talk about freezing every 10 minutes which i don't think is our problem. hmmm
    yea for me when i go to sleep at night with tv on channel lock on that station but i i do is click on the remote and good again
    get active
    The clicking on the remote won't work if you're watching PPV. It will freeze, lock up and there is no way to get it up and running without exiting. Once you exit, start it up again, it begins anew right from the beginning. I tried 3 times and the last time I made it almost half way through before it locked up and froze. Other channels do and don't depending on which channel / server you're on with TvOnline. As for DreamTv, I can get it to freeze on a whole lot of channels in less than 15 seconds. Time to dump the apps or improve the servers as I know it isn't on my end.
  1. Latino HD channels freeze
    By aanria in forum IPTV Private Server (IPTV66)
    Last Post: 09-20-2019, 07:50 PM
  2. Some freeze on all channels...
    By asesinopr in forum IPTV Private Server (NFPS)
    Last Post: 10-22-2018, 11:47 PM
  3. channels freeze and quit
    By issues in forum IPTV Private Server (Rocket)
    Last Post: 04-14-2017, 04:38 PM
  4. Channels Freeze and I have to reboot box.
    By Renato in forum aVOV TVONLINE 4
    Last Post: 12-27-2016, 03:52 AM
  5. channels freeze
    By kenl in forum IPTV Private Server (Rocket)
    Last Post: 09-16-2016, 08:46 PM
