Have tried everything--I have factory defaulted--still will not load--It goes through the two loading screens and then instead of blue bar with the yellow I get a black screen. Can someone help me?
Try doing a software update again and see if that helps.
still the same thing. Anything else?
reboot your internet router modem and mag 254
I am having the same problem, recently updated.
I had the same experience with one of my boxes. Since settings in my box seems ok, last thing I check is the URL from the provider. Its not the same settings I used to have, it suddenly change without my knowledge.
I copy the new url and everything is back to normal.
I have been having the same problem.
Where did you find the new url at.
B.
Here I am again with the same problem. Have done both things suggested and turning off everything and restarting (modem, router etc.) and it worked. Well actually it loaded into the main menu but did not use it at that time, had to go out. Last night turned it on and it would not load the (the blue bar came up but the yellow just got as far as about and inch and it stopped. Anyone? Any help?
just press the setup button and restart portal.
