Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    I said same thing but if that ez they should have done it by now
    time thing was fixed last night dont know if its a new update but its fixed
    Mar 2016
    My box is still not fixed...Is there anything I can do to force the fix? I am getting frustrated..
    Pinball Wizard
    Check internet, try using hard line instead of wifi, check timezone!!
    Mar 2016
    i have been hardwired from day 1. I also change time zone everytime it happens, doesnt help.
    Super Moderator at Work theone's Avatar
    Quote Originally Posted by rf12345 View Post
    Did you do a reset?
    yea i would try to update the box and do what theone said all this was fixed
    Rocket Recovery Technician
    Nov 2015
    Yes I do
    I've found that turning the box on & then waiting a few minutes before watching it seems to fix the date & time issue on my box;though some days it can take a bit before it corrects itself.
    get active
    I don't know if your box is set up with a time zone, auto set or manual set. If its been set up with the wrong time zone, it will reset to the wrong time. You may want to check and double check all time related settings as Mountain time and Pacific Time can be a bit confusing as I definitely have mountains here and I look at the Pacific Ocean every day.
    Super Moderator at Work catz's Avatar
    Time zone correct but no option for daylight saving.
    Update: a auto update and time is correct.
  1. Time issue on dl t1 plus
    By Sharkfhin in forum Dreamlink T1 Plus
    Last Post: 02-20-2018, 06:29 AM
  2. Time Date issue with my AVOV's
    By dascoo in forum aVOV TvOnline+
    Last Post: 08-11-2016, 04:51 PM
  3. time issue
    By mikey432 in forum aVOV TVOnline
    Last Post: 05-30-2015, 09:17 PM
  4. Avov 2 Announcement On Avov.tv
    By Falcon05 in forum aVOV VIXO 2
    Last Post: 05-03-2015, 11:43 PM
