Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    get active
    Quote Originally Posted by Laser View Post
    Love the specs and the remote!!
    Well, I wouldn't or couldn't reach that level of fondness based on the specs or the remote as I've seen and used other remotes and boxes with better specs and a better or higher quality of remote. Aside from the newer android Lollipop 5.1 and bluetooth, there really isn't much in the way of hardware or software changes although I suspect there are app changes due to the change of operating system. I did expect a newer 2.5/5ghz AC wifi and a T1000 gigabyte ethernet port which has been out and available for more than a couple of years. I did like the off/on power switch and the new square power adapter although I get shocks from it whenever I pick it up without thinking first.
  2. #22
    your the only one and what you want they didnt do so why did you buy the box i just dont get you why buy someone they told you it didnt have ? I just dont get it they posted the specs and here
    Avov TvOnline 4 PSU Replacement
    http://iptvtalk.net/showthread.php?1...SU-Replacement
    is this not great support then what is i just dont get it they try so hard to fix things that are wrong and yes chit happens
    now tell me this is not great support
  3. #23
    How do you keep input credentials in avov tv online every time I change to a different streamer it ask for Credentials again?
  4. #24
    Pinball Wizard
    Do you save after you input everything?
  5. #25
    yes I did.
  6. #26
    where in the tvoline can you save?
  1. How to use AVOV TVOnline???!
    By tinieBlax in forum aVOV TVOnline
    Last Post: 07-02-2016, 10:06 PM
  2. AVOV TVOnline box
    By tabarnak in forum aVOV TVOnline
    Last Post: 08-28-2015, 02:46 PM
  3. Avov TvOnline vs Avov Vixo 1
    By master10 in forum aVOV TVOnline
    Last Post: 05-19-2015, 12:47 AM
  4. Avov TVonline
    By floder2 in forum aVOV TVOnline
    Last Post: 04-18-2015, 06:21 PM
