Hello, how do I get the guide to fully update seems just the UK channels are not populating in the guide thanks
send me/post a screnshot of your epg with some of the missing channels..
i know on the xml epg.. a couple channels are missing. maybe 5... ill have to fix those..
im really thinking those mentioning that the uk channels are missing are using the server EPG.. as i changed a provider and the server needs to load the new channel ids
ok but I have to do later tonight I'm leaving for work my time is 2:00pm
Epg ninja works full on the plugin but not full on lastest nfps stalker client.
Lets Go !
ok i think they need to update the channel ids used in the backend.. thats beyond my control, but i will pass it on
I got the full guide working now, somehow I change from remote url to local url and got 100% guide data...windows 10 kodi 16 jarvis
how do you get the guide working on mag 450 on the lower channels
Everyday at 7-8pm my guide runs out of data for UK Channels. I delete EPG.db file and get things back and then the same thing happens the next day 730pm.
Seems like the guide just gets a partial day's data, and doesn't refresh until 2 - 3 AM, so it runs out before prime time.
I use Ivue guide for the UK channels, and at least have it display the guide data, then go back to Stalker to tune that channel.
TVFan in the West
Kodi 17.1 RC with PVR Simple Client on PC using Win 10, and
Kodi 17.1 RC with Stalker Client on PC using Xubuntu 16.04
