Results 1 to 8 of 8
    Jan 2015
    Pennsylvania
    Up and running!!
    Thanks to everyone who helped me getting my iptv up and running, I tried one last thing and WOW channels started loading back up and running about 30 minutes ago just in time for the fights tonight and Outlander!!
    Everyone!!
    Jun 2015
    Glad to hear you got everything working what fight is happening tonight??
    Jan 2015
    Pennsylvania
    Its on pay per view Manny Pacquiao and Tim Bradly
    Apr 2015
    Quote Originally Posted by wayne56 View Post
    Everyone!!
    Can you describe how you got yours up and running ??
    I thought I had mine sorted out too and it was working for a while ( a short while)... when I wen't back and turned it on, all I got was up to the blue screen with the scrolling yellow bar.... and it won't connect.....
    I'm on server 1
    Anyone having similar issues ??
    Yes, with my AVOV boxes.
    1) Go into server settings and try to connect. It won't. Wait there for around 10-15 seconds.
    2) Get back out to settings (not the main menu).
    3) Go back into server settings. You should now see the lock icon by the yellow progress bar.
    4) Click on the server and hit the connect button.
    5) It will now connect.
    Jan 2015
    Pennsylvania
    All I did was redid all my settings made sure every thing was no mistakes then did a iptv reset and it loaded channels.
    Android World
    Sometimes a fresh start is all you need, has worked for me as well.
    Lets Go !
    Apr 2015
    Thanks to user dara, I got my system back up and running....... I did what wayne did..........dara suggested I do an IPTV reset on the donation checker and that did the trick.... It's been working fine since....
    Thanks, guys !
  1. Im up and running !!!
    By zues29 in forum IPTV STB Emulators
    Last Post: 02-11-2016, 08:33 AM
  2. Up are running again
    By Actv8 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 02-10-2016, 11:26 PM
  3. Up and running??
    By Valleyboy22 in forum IPTV Private Server (NFPS)
    Last Post: 02-06-2016, 08:14 AM
  4. Up and running
    Last Post: 01-15-2016, 04:41 PM
  5. up and running well
    By jblaze10 in forum IPTV Private Server (NFPS)
    Last Post: 08-27-2015, 11:52 PM
