try choosing portal 1 or 2 and click ok..
don't understand why the identical info in both portals, not needed..
No matter which one I click with the exception of embedded comes right back and says the same thing. The embedded goes to inner portal.
I think you are confusing your box with the ident. info in both portals...your modem/router is not getting internet to your box..
did you check the back for both lites on the rj-45 jack??
Yes green and yellow light at back of box. This is my daughters' box. I had no problem with mine but this one is giving me a problem
Would it matter if I started to set up at her house and when she had to leave I brought it to my house to finish it up?
yes, because of diff IP...are you running DHCP or static?
DHCP I had internet at one time at her house but I couldn"t connect. Video said file missing
I'm not able to get to my box right now but I would def get rid of one of your portal settings..you only need our trial in one portal.
I believe you may have to reset your box but before that go to BIOS menu and ensure you're booting to NAND
I am booting to nand. Should I wait until my daughter is home to try to finish it up at her house? And why would I not get anything If I was getting internet. The setup when smooth all the way seemed to do everything right but could not get anything to work.
still waiting for an answer as to why the same info in both portals...
