Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Warrior
    Quote Originally Posted by montell View Post
    T1 has FlashVPN and CloudVPN.
    Which one do u guys recommend to use?
    is it a good idea to use VPN on T1?
    i think only one is free ,and one costs Using a vpn is your choice
  2. #22
    Apr 2016
    Canada
    Thanks man
    I guess once I download the free VPN and register for it...that'll be it ?!
  3. #23
    Apr 2016
    Canada
    by the way,
    what do the red,green,yellow and blue button do on the remote? cause there is no explanations on the User's manual about them?
    Also, what are the "LIVE" and "VOD" buttons about?
    Thanks guys for being always there for people like me
    montell
  4. #24
    what i see the free vpn do work to well better off paying for one and get the servers you want thats on any box
  5. #25
    Apr 2016
    Canada
    Thanks for the input.
    I have HMA Pro VPN...can I use it on T1?
  6. #26
    get active
    Might be easier to bridge a router to your main router, use it as an access point and have it connected to a VPN of your choice. Use that router to connect your IPTV box and voila, you never need take what's offered but choose what VPN you want without the box and its limited VPN's. I have PIA, had HMA, too many connected to their servers, found it was just too slow at peak periods, seems everyone wants to connect to Seattle servers ?
  7. #27
    hma should work fine see free ones most of time only give you a few server and they limit your bandwidth do your homework on this if you going to run more then one vpn which i do and many other things too but yes they are great tools to have i pay 12 dollars a yr for one but it does what it says it will do thats all i ask oh even some say thats helps with tv freeze just do some reading on this
  8. #28
    Apr 2016
    Canada
    Thanks a lot guys
    How about the stb emulator?
    How can I install STB Emulator on T1 ?
  1. Dreamlink T3 where to buy?
    By coolsat in forum Dreamlink T3
    Last Post: 06-06-2019, 06:36 PM
  2. APK for Dreamlink T1 Plus
    By gandzas in forum Dreamlink T1 Plus
    Last Post: 05-15-2017, 03:13 AM
  3. Dreamlink T1 Plus - DOL v1.09.08
    By zeno in forum Dreamlink T1 Plus
    Last Post: 04-19-2017, 10:31 PM
  4. Dreamlink T1
    By martys in forum Dreamlink T1
    Last Post: 04-16-2017, 05:15 PM
