Results 11 to 20 of 28
    Can we setup a VPN like the avov box
    Warrior
    Quote Originally Posted by grodri1972 View Post
    if there is an app it can be added to marketplace
    HD stands for Harley Davidson 4wheelin's Avatar
    nice box and set up is great ,picture is as good as i expected from dreamlink ,now have to play around with it and figure out a few things.
    Scrolling is fast in Kodi and the DreamOnline app. You will need that as there is no 'page up/down' on the remote. Great picture quality, and very easy to set up for IPTV. Currently 27 apps in the Market. New users should expect to see a firmware update when connected to the internet. There are 2 VPN apps in the Market (FlashVPN and CloudVPN).
    My only minor negative is the limited remote... very basic functions.
    VIP Member B_Madd's Avatar
    Dara the remote will page up and down if you use quick use by hitting OK on remote, and using the up and down arrow on remote. If using the epg mode it doesn't work that way as it gives you a couple hours in advance for each channel.
    Apr 2016
    Canada
    Hi everyone,
    Thanks for the great forum..you are Da Best
    Quick question: why is the Mouse arrow so super slow when moving across the screen ?!
    any fixes for that?
    Also, how Do I update the software.
    montell
    Warrior
    Quote Originally Posted by montell View Post
    Hi everyone,
    any fixes for that?
    montell
    no idea about the mouse,dont have issues
    You dont update ,it updates itself
    Apr 2016
    Canada
    Thanks for the reply NBS
    How about the VPN...any idea how to use it on the T1 ?
    Warrior
    you should be able to google it Users have posted it works
    Apr 2016
    Canada
    T1 has FlashVPN and CloudVPN.
    Which one do u guys recommend to use?
    is it a good idea to use VPN on T1?
  1. Dreamlink T3 where to buy?
    By coolsat in forum Dreamlink T3
    Last Post: 06-06-2019, 06:36 PM
  2. APK for Dreamlink T1 Plus
    By gandzas in forum Dreamlink T1 Plus
    Last Post: 05-15-2017, 03:13 AM
  3. Dreamlink T1 Plus - DOL v1.09.08
    By zeno in forum Dreamlink T1 Plus
    Last Post: 04-19-2017, 10:31 PM
  4. Dreamlink T1
    By martys in forum Dreamlink T1
    Last Post: 04-16-2017, 05:15 PM
