Results 1 to 10 of 13
Thread: tv guide
    Probation
    Feb 2016
    ya
    tv guide
    whats a good tv guide to use ivue tv not loading time line guide or does it work or do i need remote url what works thanks
    In the hills
    i'm not sure
    tux tux tux
    Jul 2015
    in my head
    lol thanks for the lesson psycon.
    “there is nothing wrong with being insane, as long as you know it yourself.”
    Probation
    Feb 2016
    ya
    psycon thanks but when you get of a tv guide that works please update info
    Compound questions are hard to answer.
    Probation
    Feb 2016
    ya
    hi epg is up working :}}} time line etc
    Good. The best thing to do is do some exploring here, and you'll most likely run into the answer you need on your own.
    unbanned christmas
    Jul 2015
    Looking for a new TV guide to use with Stalker IPTV because my iVue2 guide just gets stuck at the loading screen, so does FTV Guide.
    Not sure what is wrong
    Dredging up an old thread that doesn't really answer anything doesn't help.
    You can start your own thread about developing a new source for an EPG... that's what this subforum is about. The ninja efforts were forked away into its own forum as it became its own animal, so to speak. For now, there are these options:
    1. Use the provider EPG which works for some STBs, and may work for PVR Stalker on Kodi
    2. Use a third party EPG add-on for Kodi, that can be adapted to the services.
    3. Create your own epg pull from the public sources, and integrate it into Kodi.
    Member Waylotul's Avatar
    Jan 2016
    I am with your advice, I have been in here all day, for days. The three points you make are good. I am looking for any sticky technical on the first option from provider. I am focused on my provider as opposed to the third party stuff, that is great, and I donated and I got what I paid for however, everyone is not able to sort the good the bad the ugly since things change so fast around the bleeding edge of tech. Many I think thought that ninja was doing fine and reliable but it got flaky but hey it was free. If you can point directly to some links about papiao EPG pulls for Kodi, I would love it. I don't see psycon posting anything, he was so helpful for so long. Is that gone forever?
