Add the server 66.iptv66.tv and it pops up a credentials screen. Entered the route # as the username and password but it doesn't connect. Am I doing something wrong here?
reset iptv mac adress via donation search and try agian.
Lets Go !
I tried that. No luck. Still having the same issue. In fact, tried it with another server too and it's doing the same thing ... Keeps popping up the credentials dialog box.
did you have your box unplugged while you did the iptv reset?
credentials dialog box want the password and username
Still having the same problem. I don't have a username and password - just using the route donation # for those fields. Is that correct? If so, is there a way for me to check if its the box that's bad?
Send me a private message with your donation code and yes the donation code is both user and pass.
Also send me your mac addy but only send that stuff to me in a private message ok.
Android Man PM sent
same problem you resolved, AVOV tvonline plus not connect to iptv66 server
Maybe iptv service is down could be effecting tv-online
Lets Go !
