Results 1 to 8 of 8
    Rocket subscription - is there a problem currently?
    I'm using a fire stick and kodi 15.2 and everything was working fine until this morning. When I open kodi now I get the usual message in the top right 'loading channels from client' and does not appear to make any progress. After approximately 1-2 mins I get the message 'Unable to load channels' is the service down at the moment?
    HD stands for Harley Davidson 4wheelin's Avatar
    server is up ,using fuse here .
    Reboot the stick. Things are working here on my stick.
    Ok, well at least I know the issue is on my end. I've tried rebooting the stick a number of times and also disabling the stalker client and turning it back on to no avail.
    I would try an IPTV Reset then.
    In order to do an iptv reset I'm assuming you just mean sign in with my donation number and press the iptv reset button?
    Yes, sir...
    Feb 2016
    North Pole
    Quote Originally Posted by charp9710 View Post
    yes that is correct.
  1. Problem inputting mac address in New subscription
    By Imp08ala in forum IPTV Private Server (NFPS)
    Last Post: 05-03-2023, 10:12 PM
  2. New Rocket Subscription
    By Snowgoose in forum IPTV Private Server (Rocket)
    Last Post: 04-30-2019, 03:15 PM
  3. Renewed subscription Problem
    By Scanner in forum IPTV Private Server (Rocket)
    Last Post: 11-06-2018, 05:03 PM
  4. subscription NFPS problem renew
    By pedrer in forum IPTV Private Server (NFPS)
    Last Post: 08-30-2016, 04:20 PM
  5. changing my mac id on my rocket subscription
    By shannick in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 09-08-2015, 10:56 PM
