Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: Down again
    Warrior
    Jul 2015
    yes I do
    Quote Originally Posted by pod77 View Post
    Actually no freezing here so check your setup or ISP provider... Please tell us how things are going "Backwards" if anything things have gotten much better...
    I've been having freezing problems this afternoon/evening... this morning it was working fine. I am running a continuous -t ping on 66.iptv66.tv (my server using a Mag254) and when the tv freezes for 5 seconds the pings do not drop at all, so it's not an ISP problem, if it was the pings would miss as well. I tried VOD and same problem there, I can normally watch a movie no problema.
    It may be that the peeps not having problems are not on IPTV66 as there are 3 different servers/ip's. Just my 2 cents.
    lost a connection on a channel, but changed the channel and all was good again
    iptv66 last few hours with Fuse box
    and just lost connection again
    iptv66
    Fuse
    Warrior
    Jul 2015
    yes I do
    It has been working really good... just the disconnect problem... will check it later on... for now turn on the IKS box
    Mar 2016
    sure
    iptv66
    Fuse
    Ah even the super mod is having problems so that means we all aren't going crazy. lol. Seriously though I thought my ISP was the culprit.
    Mar 2016
    Europe
    I've only had the service a couple of days on a MAG254 but never had a connection drop. I have had problems loading the portal with it taking up to 10 attempts to load, but once loaded it's pretty stable. It was good around 10pm Eastern when others were having issues
    Mar 2016
    sure
    Quote Originally Posted by fatman14 View Post
    Exactly what country are you in fatman14?
    I'm in the UK and not noticed any lagging or sync issues on most US channels. I'm using a MAG254
    Are you just converting your timezone to eastern time?
    Warrior Member
    66 seems to be working good for me....
    tester
    Yes I do
    66 down on both avov fuse
    Jan 2016
    66 still down ..
