Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Banned
    Update:
    So after a factory reset of the MX box running 4.2
    Fresh install of kodi, same problem. Sound with no picture. The icons are visible like play, stop, ff, rw etc.... But just no image. Tried changing acceleration settings. No joy. Tried all the box settings in regards to HDMI detection, no joy.
    This problem only began when he upgraded to Jarvis 16. Running on 15.2 was fine so it leads me to think that something is not compatible somewhere. Even changed the HDMI cable for good measure.
    Considering upgrading firmware, Any suggestions as to where I can find the right information for this if all other options are exhausted?
    Banned
    Model number: MBX reference board (g18ref)
    Android version: 4.2.2
    Build: JDQ39. 20141205
    Kernel: 3.0.50
    This is the information he can see
    tux tux tux
    Jul 2015
    in my head
    I can confirm that to it is for sure compatible. I suppose you also tried lastest 16.1 RC1.
    you can also try switch resolution of the box to 720P and see what happens.
    “there is nothing wrong with being insane, as long as you know it yourself.”
    Banned
    OK I'll try to change the resolution, I assume you mean in the front end of the box and not in kodi itself
    Banned
    Just letting you know that my friend told me his box was and MBX, what he meant was M8.
    Will keep you posted as to what happens
    Banned
    Got it sorted, turned off the acceleration in video settings, seems to have worked.
    Thanks for all your help
    Junoir Member Neal Perry's Avatar
    Apr 2016
    Try going to the system and after that, go to video. And to Acceleration and make sure decoding method is on hardware accelerated. Then highlight all underneath, This time go to setting, other, more setting and then storage and scroll down to cache and clear for all apps.
  1. No picture or sound
    By Roger1684 in forum Mag 322
    Last Post: 07-21-2020, 01:07 PM
  2. Sound but no picture
    By supaman32052 in forum Dreamlink T1 Plus
    Last Post: 10-22-2017, 06:43 PM
  3. No picture but I have sound
    By srnnng in forum MAG 256 & MAG 257
    Last Post: 12-08-2016, 02:16 AM
  4. Sound & Picture
    By icementeam in forum aVOV TvOnline+
    Last Post: 12-08-2015, 05:30 PM
  5. no picture or sound
    By Italfrank in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 09-06-2015, 11:31 PM
Tags for this Thread
