Results 1 to 4 of 4
    Mar 2016
    sure
    What Should I Look for in a Long Range Wifi Adapter?
    I'm looking to get a wifi adapter for a mag254 I ordered. I am going to need one with a good range because I plan on moving to a bigger location and may possibly have two floors. Need something that if my router was on the first floor (and assuming the router has a good wifi signal range), then my mag254 wifi adapter on the 2nd floor would be able to pick up the connection and stream fine. I know this is possible as my dad in law has a router locked inside a cabinet in the basement and I still got good signal on the main floor.
    Warrior Member
    I find this better to use,
    http://www.ebay.ca/itm/COMFAST-Wireless-Repeater-300M-Network-Router-WiFi-Signal-Range-Extender-EU-Plug-/152000979448?hash=item2363f6e1f8:g:nUIAAOSw3ydV4XnM
    Plug it in behind the tv you will never see it.
    Plus has great wifi on it but you can plug your mag into it like i do...connection never lost.
    I run nanosat cost around 35 dollars each but will worth it when setup right have very big house and this works the best for me but it not a repeater
    Mar 2016
    sure
    Quote Originally Posted by Android Man View Post
    I totally forgot that I'll have an extra router which has a repeater built-in. This extra router is my main one now. It was fairly cheap when I bought it ($10) and the range isn't all too good (has trouble penetrating walls). But when in range it does a pretty good job. I might just get an extender to use with both of the routers if the routers by themselves aren't good enough. I don't plan on running ethernet into an extender though. That being said, if my range extender is good then I guess my wifi adapter for the mag254 doesn't need a whole lot of range. The entire place I plan on moving too has square footage ranging from 1500-1900 spread among two floors so hopefully if I have to buy anything, I can get it for under $20.
    Where could one purchase nanosat? I googled the term and saw pictures but not an official manufacturer. If they are significantly that good I wouldn't mind spending a little extra.
  1. MAG254- wifi adapter not connected error
    By Phat84 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 04-21-2020, 04:37 AM
  2. Formuler Z7+ USB WiFi adapter compatibility list
    By crazed 9.6 in forum Formuler Z7 & Z7+
    Last Post: 05-23-2018, 01:25 AM
  3. Wifi Adapter question
    By Wyzzard in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-23-2017, 08:18 PM
  4. MAG 254 wifi adapter?
    By greatest in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 10-04-2016, 08:36 AM
  5. Comfast Wifi Adapter
    By harry22g_s in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 09-19-2016, 12:21 AM
Tags for this Thread
