Hello guys
My EPG don't work anymore. I got one or two channel with guide.
I erase all data twice, reboot all, modem....
nothing.
An idea ?
(Kodi 16 with EPG ninja add on)
Hello guys
nothing.
An idea ?
http://iptvtalk.net/showthread.php?1...Updater-plugin check this out
thanks ASFT, but i did it already...
nothing load. channels ok...
was working perfect yesterday
sometimes you need to wait give it a few mins have not check mine
still not working.
but i got guide for some channels like spain costa rica....
what can i do ? i got the epg add on and all the thing.
Same here... My xbian updated to Kodi 16, wan't able to use NFPS PVR anymore, had to switch to PVR Stalker Client, worked fine for a day or two...
thanks darkside.
That's why it don't works since yesterday. So i will change nothing. And wait.
But for now, i've found a quick solution for good that will always work. Renegades TV guide. My 30/40 channels in favorites, linked in it. And go
A bit long to link, but after it's creamy.
you can change the guide preference to prefer xmltv and the provider epg will load until the ninja one is back up
ahhhhh very cool !
Ok, mine is set on "only xmltv" indeed. I will try tonight.
Thanks again !
