Results 1 to 8 of 8
    Jan 2016
    help with stalker setup
    well i have my mac address and donation number but I accidentally cleared my data...I used to have the instructions yhat came with mac address but miss placed it now i need help on how to go about getting the stalker set up ...does anyone have like a walk threw or video on how to input my mac address and donation number. ..I keep getting failure...thank u!!!
    Member Gtest413's Avatar
    Jan 2016
    What version of kodi are you using?
    Jan 2016
    Actually, do yourself a favor and get kodi 16.
    Then, go here and follow.
    http://youtu.be/K_05s-3vsHk
    http://youtu.be/Nj3dz6OEsxA
    Shout out to Tech Timeruuu for his great guides.
    Feb 2016
    of course
    Tried following both gides several times, fresh installs an all.
    Cant seem to get iptv66 sub working on my firetv with kodi.
    It does work with the stb emu so i know ive got a good mac.
    Any suggestions to get it working in kodi?
    I get an auth failed error with device id mismatch message.
    An of course ive reached my reset limit for the day with iptv66. That limit is enough to make you loose your mind.
    Jan 2016
    You need to enter the right url for iptv66. I think that guide is for nfps.
    "No one learns as much about a subject as one who is forced to teach it"
    Jan 2016
    I tried doing both and still not working any idea what can be wrong ?.I checked mac and donation and they are both good
    wickedjoker wickedjoker's Avatar
    Starkiller Base
    Quote Originally Posted by socalnugz View Post
    Mods can you move this hijacking others post.
    Starkiller Base
    If you if you have an issue with pvr.stalker.nfps or cannot connect at all Look through the posts or start a thread in Here: http://iptvtalk.net/forumdisplay.php...TV-PVR-Simple)
    IF you can connect fine, but your epg isnt working correctly or shows up grey and missing quite a few channels. Look through the posts or start a new thread in http://iptvtalk.net/forumdisplay.php?97-EPG-(epg-ninja)
    Remember too. the site has a search function up in the top right corner, USE IT. your issue has probably been asked and solved numerous times.
  1. How do I setup with stalker
    By dreday468 in forum Amazon FireStick & FireTV
    Last Post: 01-14-2018, 11:24 AM
  2. Papiao Stalker App Setup Help
    By u2kthundar in forum IPTV Private Server (NFPS)
    Last Post: 04-09-2016, 04:34 PM
  3. help with stalker setup
    By Marcus1183 in forum IPTV Private Server (NFPS)
    Last Post: 04-06-2016, 07:15 PM
  4. stalker setup
    By nelsonlfs in forum IPTV Private Server (IPTV66)
    Last Post: 02-20-2016, 07:33 PM
  5. Replies: 4
    Last Post: 10-21-2015, 09:23 PM
