I installed stb emulatotr v. 7.1.2 on an amazon firestick, i get no sound on any of the movies, but i do get sound on the live tv part. im using papiao.
what do you mean by that explain a little more
Same on my set up with fire tv. No sound at all
check this sound out !!
Do not forget to crank it
sorry for interruption , but I had to .. is the devil in me
Change player to ijk
Hey I figured it out.
Download mx player on whatever and side load it to your stick.
Open up stb and click on a channel. Hit the three bar button on remote and select "media player"
Then click on external player.
A menu should come up asking what external player to use.
Click on mx player and then hit "always".
This fixed the sound problem.
If the external menu doesn't pop up right away unplug your box and try again. Took me about 15 times to figure it out.
Goodluck
nice work Gtest
Thnx .. should get this into a guide here somewhere
I will look
