plus model does not have that option.guy above says he installed 16.0 on the plus.really?
Hi Guys
I have the Avov TvOnline+ & have updated to Kodi 16 without any problems. Follow these instructions:
Download Kodi (15.2) from the Mickyhop Market, Run it when it has installed & let it take its updates. Fire up your browser & log onto http://kodi.tv/download/
Navigate to Kodi 16, Android & select ARM. A message will briefly appear (Starting Download) After approx 3 mins close the browser & fire up Kodi (15.2) select Program, then Android Apps (I think its in here, If not try Program Apps) Its been a few weeks since I did mine. Scroll down & open Download Directory, click onto Kodi 16. It will install then close itself. Launch Kodi & Hey Presto you will have Kodi 16 installed.
Enjoy
Wizard1
P.S
Please Mickyhop, get your finger out with Kodi. I know lots of people that won't buy Avov, because they won't wait for these important updates.
tell that to many companies avov is not the only one and fuse is set to any you want
Just tried wizard1's technique and it says can't open file when I click on it from the download folder.
didnt worked
just tried it didnt worked for me too!!!
Never give up until you succeed!!!
Hi Guys
Have you put 15.2 on first & let it update ? Otherwise it will say can't open file. Do you also have latest Firmware on your box ?
I have just Factory Reset my Avov TvOnline+ & successfully re-installed Kodi 16 using the above instructions.
Regards
Wizard
Dumb question perhaps…is there no way to update from within Kodi itself? If I wanted to go from 15.2 to 16?
Hi Autoroam
It can't be done that way.
Regards
Wizard
it freakin work,dang!!! thanks wizard now i have jarvis 16 in my tvonline+
