Results 1 to 10 of 12
    Member 1932ford's Avatar
    how to set up a mag 254 and 360 elite with on cat 5 cable ...
    ok ,,i understand that about the hub or switch but my Modem and Router and Hub are all upstairs with one computer and a mag 254 all connected by hard wire also downstairs in the living room i have a 360 elite and a mag 254 and in my bedroom downstairs I have a second computer and a 360 elite and a mag 254 all hardwire but in order to watch either the 360 elite or the mag 254 i have to keep switching out the cat 5 cable from one to the other , i dont want to run seperate 100 foot cat 5 cables again from up stairs to downstairs and for some reason i can not get my wifi adapters to work i have bought 2 USB 2.0 wireless 802.lln adapters but for some reason they wont connect ,,so i am asking some one with the knowlege if they know what i can do ,,,so if i can run a nother hub where would it go thank you
    HD stands for Harley Davidson 4wheelin's Avatar
    i use netgear wireless adapters ,they work good here.
    4wheelin,,, what model number
    im useing the xe105 ,had them along time now.
    I have an androuid tv box, 360 elite, internet phone, my pc and wife pc with nothing wireless. My elete, android tv box, and phone are close to my router and use 3 of the ports for them. I have 1 powerline connected to the 4th post with a second powerline connected to my pc and one powerline upstairs where my wife runs her computer. One powerline acts as a sending unit and any connected to another device acts as a receiver. Have no connection problems and all mine are connected with cat5.
    the Ralink RT5370 chipset works well (I use this on both Jynxbox STB and Mag 254)
    Banned
    STB MAG200 MAG250 and MAG 254 supports the following Wi-Fi adapters:
    Model 	                  Chipset 	             Revision/Notes
    ASUS USBN13	           Ralink RT3072        revision B1 is not supported
    DLink DWA125	           Ralink RT3070        H/W Ver.: A1, A2
                                       Ralink RT5370       after release release-0.2.12)
    Edimax EW-7711UAN     Ralink RT3070
    Tenda W311MI	           Ralink RT5370	      after release release-0.2.12
    TPLINK TLWN727N	   Ralink RT3070       after release release-0.2.12
    Dune HD Air	           Ralink RT3070	      after release release-0.2.12
    65 ft away wireless on cheap knock-off 4 buck on ebay
    You can use an Ethernet switch like this and you don't need to go wireless. A hardwired Ethernet connection is best for streaming anyways.
    Just plug your one Ethernet cable into the switch and now you have multiple ports.
    hxxp://www.amazon.com/TP-LINK-TL-SF1005D-5-port-100Mbps-Desktop/dp/B000FNFSPY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1425749026&sr =1-1&keywords=4+port+ethernet+switch
    Android World
    I perfered wired but if you have a long run wireless is the way to go.
  1. Cable is Dead App
    By fox321 in forum Amazon FireStick & FireTV
    Last Post: 06-18-2021, 08:14 PM
  2. Replies: 1
    Last Post: 10-02-2017, 12:33 PM
  3. Replies: 31
    Last Post: 09-25-2017, 01:16 PM
  4. IP Cable Cloud - Multiple provider cable over internet guide for Papiao
    By bloodhod in forum IPTV Private Server (Rocket)
    Last Post: 09-09-2017, 08:26 PM
  5. Was Cable Better
    By conwarn in forum PVR Clients
    Last Post: 03-04-2016, 02:26 PM
