Mine is down for about 4 hours now. It was working ask day.
Mad 254 down
I have tried clear data a few times. still shows authentication fail.
Running Mag 254 . Loads to the blue portal bar but never progess's past it. Am I doing something wrong? Never asks for authentication , just sits at blue bar.
Ok once again (kodi users): Go to System, live tv and disable Live TV. Click Clear data after that. Then, go to Addons, My addons, PVR Clients, Configuration, Portal 1. Here you will check that the Mac is correct, server address is ok, check that Login and Pass are filled with the donation number, Serial number is filled with a 12 number plus 1 letter combination (13 character) and theeeeen, you take the Mac, serial number and donation, and copy/paste them into a SHA256 online conversion page (GOogle it!). Insert it on the space provided and hit the conversion button. The result will be a very large code that will be your new Device ID. Device ID2 and signature can be left blank. But don't click OK yet!! go to Papiao site, fill in your info (Order#, Donation #, Capcha) and you will reset your iptv. After you do the reset, you can go back on Kodi and click OK. Then, go back to Live TV and enable it. Andddddd .................... TRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR! Wa lá! TV again. Pretty easy...
I've just noticed now i can't change my ip address this is getting weirder as we speak
Still authentication failed
Dont change your settings if it was working fine for weeks prior.
